Ir para o conteúdo principal
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
150 Perguntas Visualizar todos
speedometer stopped working on 2005 Pontiac Grand Am
The speedometer needle moves on engine startup but not during movement of the car. All other instrument cluster needles move OK. Odometer is not recording any increase in mileage during movement of the car.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Theo, this is most likely a problem with the instrument cluster or the speed sensor. Instrument clusters made after 2000 have Stepper Motors to drive all the gauges including the speedometer. I'd start with the speed sensor since it is a lot cheaper. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Theo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 1,883
