Ir para o conteúdo principal
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
now it wount charge at all
My galaxy s2 has only a couple months I got it, at first I could use it while it charged and all but later the charger didn't work while I used it so I would leave it alone and it would charge but later on I had to put pressure on it or put it some way so it would charge, now I had to charge it on my computer but now it wount charge at all and ive tried everything on it I don't know what to do with it anymore.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
may, I would try a new battery first. If that does not work, you do want to check on the charging port flex and see if replacing that will work. If that still does not work, you are going to have issues with the charging circuit on the logic board. Here are the guides to work on your phone. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
may será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 107
