Ir para o conteúdo principal
Quinta geração da Pickup da Toyota
Where are the fuse boxes
where is the fuse box inside 93 toyota truck
Esta é uma boa pergunta?
Pontuação 3
1 comentário
No power al
interior Toyota 4Runner 93
por
Adicionar um comentário
3 respostas
Solução escolhida
MIKE, it sort of has three. One is by the left kick panel, one is under the hood right behind the battery and then there is a junction box with two fuses for the AC/Heater behind the glove box. Hope this helps, good luck.
Imagem
Esta resposta foi útil?
Pontuação 6
2 comentários:
My fuse box cables are melting, what's happening..?
por
Kholo Bree all of them? You got a short in the wiring going to the fuse boxes. We need a lot more information and possibly some pictures. What year? What model? What have you checked?
por
bad alternator or bad battery or both huge short in starter wire
Pontuação 0
check fusable link in fuse box in engine ok power to all fuses turn ignition on nothing. head lights horn brake lights work except wipers
Pontuação 0
1 comentário:
The alternator light doesn't work and when I plug in obs it doesn't have power either?
por
Adicionar a sua resposta
MIKE será eternamente grato(a).
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 30
Últimos 30 dias: 102
Ao todo: 54,114
