Ir para o conteúdo principal
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Perguntas Visualizar todos
Pergunta encerrada
Why is the replacement battery draining so quickly?
I just installed iFixIt's replacement iPhone 3G battery and it seems to have drained awefully quickly. (No, I don't have any background apps or emails going). It seemed to lose 1% battery life every ~30-60 seconds for a while
Esta é uma boa pergunta?
Pontuação 0
1 comentário
new or used?
por
Adicionar um comentário
2 respostas
Pergunta mais útil
... or if the replacement battery is getting warm/hot during this discharge, something on the logic board could be shorted and is causing the battery to drain.
Esta resposta foi útil?
Pontuação 1
Sounds like you received a bad battery, you should contact iFixit and get them to send you a new one.
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 1,460
