Ir para o conteúdo principal
Um smartphone no formato de tablefone com caneta stylus, lançado pela Micromax Mobile em 2013.
Recover data from A240 internal memory
My phone is not getting switched on. i tried many things
power btton+ low volume key etc.
service centre have said to rplace the motherboard.
i need my data badly from internal memory. service centre is not helping. need some one immediate help.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
Data is proprietary (you won't be able to read it). If you can pull the SSD the phone center should be able to mount it in a new phone. If not go up the line until you find someone who can help you.
If this answer is acceptable please remember to return and mark it.
Esta resposta foi útil?
Pontuação 1
vib, the data is stored on t\some hardwired NAND memory chip. Unless you can build a NAND reader and have the software to access the chip, there is no way you can get to the data. Some data recovery centers do have that equipment, but it is very costly to use their services. Sorry, but a normal DIY'er and normal repair shop will not have access to that method. Hope this helps, good luck
Pontuação 1
Adicionar a sua resposta
vib será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 1,200
