Why is there no sound?
The volume is up fully and will not produce any noise! Help!
Esta é uma boa pergunta?
You might have a bad speaker or audio jack. In the case of the speaker you would need to check the connection between the speaker and motherboard. If it was due to the audio jack, cleaning it with an air duster may help. Check out the Troubleshooting page if you any issues.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 33
Ao todo: 7,175
4 comentários
What is the exact model of phone you have? That way I will be able to further help you know what the exact problem is with your phone.
por computeripodrepair
@computeripodrepair, LeapFrog LeapPad2 Explorer is a childrens learning tablet, not a phone!
por oldturkey03
Andrew Gough, what have you tried so far? how long has this been going on? Has anything happened just prior to it failing?
por oldturkey03
My daughter own is the same problem no sound
por asheena lawson
