Ir para o conteúdo principal
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Perguntas Visualizar todos
What is the best tool to use for the standoff screws?
the bloody standoff screws in the iphone 4 are so hard to find a good fitting tool for! What is the best tool that someone has found to handle the standoff screws???
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Here you can find different market reports about tools-
https://www.factomarketinsights.com/
por
Adicionar um comentário
4 respostas
Solução escolhida
I take a small Phillips and grind it down flat and that allows me to have connections at all 4 slots. I find the flathead slips out a lot and harder to put back in with flathead.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Excellent solution. This really works.
por
You can find all the repair tools on ifixit. You can see the iPhone 4 tear down and can see the tools.
Pontuação 1
Very small slotted (flat) head screwdriver.
Pontuação 0
1 comentário:
1.5mm flat head has been my preferred choice
por
Since you asked this question, iFixit added a special standoff bit to their tools catalogue.
iPhone Standoff Screwdriver Bit (Item code: IF145-343-1)
I use a 'STANLEY 63-310 U.S.A.' pocket slotted screwdriver for this task. It is good, though not perfect: its blade is just slightly wider than screw head, so it will collide into nearby components. I need to slide it slightly after every half turn, so it overhangs clear/free area, instead of overhanging populated area and bumping into parts.
Pontuação 0
Adicionar a sua resposta
Stephen Jennings será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 21
Duração total: 1,697
