Ir para o conteúdo principal
15,6", Intel HD Graphics, Core i3 2330M, Windows 7 Home Premium 64 bits, 4 GB de RAM, HDD de 500 GB
Heat problem
Hello i have a problem in the high-temperature device to 93c
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
sawalha, make sure that you when operate your laptop that you do not occlude the air vents. Keep the laptop off soft materials, like cushions, pillows and blankets. If it still gets hot, you will have to take it apart and clean the air vents, the fan as well as considering replacing the thermal paste on the processor. Start with the cleaning first, then re-evaluate. You can download the service manual from the bottom of this page. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Will echo this and say its always good to replace the thermal compound between the heatsink and the CPU. The cheaper stuff stops performing well after a couple of years.
por Compartilhar
Adicionar a sua resposta
sawalha será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Ao todo: 1,805
