Ir para o conteúdo principal
The most popular option to light large areas of buildings. They come in a variety of connection types and power ratings.
The light has turned pink. Is this dangerous?
Our fluorescent light has suddenly turned pink. It is a large double light in the bathroom. I have not seen this problem on any of the sights.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I am having the same issue with flukers 24 inch uv reptile bulbs.
their a t8 20 watt bulb.
por
Adicionar um comentário
5 respostas
Solução escolhida
Darla, no it is not dangerous. Often fluorescent lights will turn pink (caused by a loss of mercury) with black burns on the ends of the lamp as the light reaches its end of life. Replacing the light tube should fix this. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 3
5 comentários:
This is a brand new CFL (the long-life screwy looking ones) light BULB, not a fluorescent light.
por
One other possible factor, my pink glowing bulb was manufactured in China by TCP (whatever that means) and the box says it does contain mercury.
por
in my case original tube was white with black ends. Replacement tubes were brownish and worked properly in other fixture.
por
CFL stands for compact fluorescent light
por
We have retubed a supermarket with 58 watt Philips lamps.
A good percentage have gone pink. Philips are saying they have never heard of that occurring.
This has happened in fittings that have the old wire wound ballasts as well as electronic ballasts.
Not dangerous but not good!
Pontuação 0
1 comentário:
The voltage going through the tube will cause the tube to breakdown sooner. You maybe not using the correct tube for the fixture Guide to Fluorescent Lamp Compatibility
por
Loss of mercury you say. Where did the mercury go? Sounds dangerous
Pontuação 0
2 comentários:
The mercury is still in the tube!
Think how your mirror gets fogged up after you take a hot shower. The cold surface of the glass collects the condensation from the moist air.
Basically, thats whats happing here the mercury vapor condense at the colder part of the tube. Thats what the black area is at the ends.
por
Mercury vapour gets obsorbed into the phosphorus paint & inner glass this means the Mercury gas pressure drops to a point where it can no longer light up leaving only the argon gas to exsite which light up pink
por
Very dangerous, have you changed the bulb?
Pontuação 0
Probably darla. Sounds dangerous.
Pontuação -4
1 comentário:
So is your answer.
por
Adicionar a sua resposta
Darla será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 50
Últimos 30 dias: 265
Ao todo: 73,416
