Ir para o conteúdo principal
7.9 inch display / Model A1455 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
Cracked glass-Do I have to replace the whole LCD Assembly?
I have a Mini with cracks in the glass on the front. I see instructions for replacing the front LCD panel. Do I have to do that or can I just replace the front glass?
Thank you!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Ricky Earl, follow this guide iPad Mini CDMA Front Panel Assembly Replacement
Esta resposta foi útil?
Pontuação 1
Depends on the shape of the LCD when you get it he digi off. Your LCD could still be fine, just be careful when attempting to remove the LCD it is adhered to a metal plate and it's easy to screw up the LCD while attempting to remove it.
Pontuação 0
Adicionar a sua resposta
Ricky Earl será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 449
