Ir para o conteúdo principal
O Kindle 4 possui 4 modelos lançados em 28 de setembro de 2011.
Kindle will not switch on
my kindle was fine when I switched it off, but will not turn on again. I have tried this with the mains connection on & off. When pressing the on/off button, the green light comes on, briefly, then --- nothing!
The charging light seems to work, but the kindle will simply not boot! Any suggestions?
Esta é uma boa pergunta?
Pontuação 4
6 comentários
the back won't come off
por
got the back off wares battery
por
kindle 4 will not let you take it out what do i do how
por
the battery is glued down
por
I fixed it by disconnecting and reconnecting the battery. I followed this tutorial: Substituição da tela do Kindle 4 until step 2, then reattached the battery and reassembled the back.
por
Exibir mais 1 comentário
Adicionar um comentário
3 respostas
Pergunta mais útil
I had the same problem as you.All you need to do is hold in the start button for 20 seconds and it will reboot the kindle and it will reload everything.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Worked for me! I think my initial problem was I left the kindle battery to drain for too long. I need to remember to charge it. Thank you!
por
i had the same Problem with a kindl. Disconnect the battery from the logic board, wait for about 2 minutes and connect the battery to the logic board. This helped me...
Pontuação 0
2 comentários:
After watching fixit so knew how to take back off ,I followed advice about disconnecting battery did this left for few minute.....now have a working kindle again.
por
can you direct me to get the instructions for removing the back please as i have the same problem.
thank you
por
I am having the same issue. How do I open Kindle 4 to do this? Can someone please direct me to a good, reliable set of instructions? Thank you.
Pontuação 0
1 comentário:
yes i would like the instruction
por
Adicionar a sua resposta
Denis Keenan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 27
Ao todo: 3,240
