Ir para o conteúdo principal
O Game Boy foi lançado em 21 de abril de 1989 no Japão, seguido pela América do Norte em 31 de julho de 1989 e, por último, na Europa em 28 de setembro de 1990. Ele é caracterizado por um grande invólucro cinza e o número de modelo DMG-01.
Original Gameboy will not turn on.
I found an original Game Boy that i haven't play in a long time. I have added new batteries and turned it on but nothing, not even the red light will turn on. I haven't opened the console yet to check what may be wrong. I do not want this console to go to waste. What should I do?
Esta é uma boa pergunta?
Pontuação 7
Adicionar um comentário
3 respostas
Solução escolhida
ross, the very first thing you want to do is to clean the battery contacts. Make sure they have not corroded to badly. If those are okay, you will have to disassemble your GB and take a look at the components. You could try and clean it with some isopropyl alcohol and carefully check to see if there is anything obviously corroded etc. But until you have it apart, anything will only be a guess. Use these guides to help you with taking it apart. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 6
3 comentários:
@oldturkey03 what do you do if it is corroded badly? I have come across an old DMG-01 which one pair of contacts is badly corroded. Thanks in advance.
por
@richielegend depends on the damage etc. We would have to see that. Cleaning the board and possibly repairing damaged traces might be a fix. Big depends on what this all looks like
por
The contacts are on a separate piece. Two contacts for two batteries. But what the contacts are on is a small plate. That's has corrosion, but I only have to try to clean contacts itself. Not sure if I can take the two contacts out. It snaps into place
por
Hello. Have the same problem and fix it with contact spray to power switch. But first you got to unscrow six scrows of game boy shel to spray directly to switch. Sorry for my english. Good luck!
Pontuação 1
One thing I always do is use the DMG Game Boy DC adapter and see if it turns on that way, if it does then you will need to clean the battery contacts, if it does not power on with the DC adapter then the Game Boy is pretty much beyond repair, I hope this was helpful.
Pontuação 0
2 comentários:
Well I don't have the adapter
por
Try picking off the corrosion first, check the board to see where the corrosion spread
por
Adicionar a sua resposta
ross será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 47
Últimos 30 dias: 240
Ao todo: 38,609
