Ir para o conteúdo principal
Lançado em junho de 2009 / Processador Core 2 Duo de 2,66, 2,8 ou 3,06 GHz
Location of the WLED driver
Imagem
Can someone tell me where the WLED driver on this Macbook Pro? This is a Macbook Pro 15" 2.8Ghz Mid 2009 EMC 2324. I have also included pictures. Thanks in advance.
Imagem
Imagem
Imagem
I'm sorry, but I couldn't find the last three digits of my serial number.
Esta é uma boa pergunta?
Pontuação 2
7 comentários
Kevin, not sure where you posted your images:-) use this guide Adicionar imagens a uma resposta existente to post your images with your question. Also, it will help tremendously if you give us the last three digits of your computers serial number.
por
I just uploaded the pictures. Sorry about that.
por
Hey, no problem:-). do these look like the specs for your computer:" 2.53 GHz Core 2 Duo (P8700)
Intro Date: June 8, 2009 Disc Date: April 13, 2010
Order No: MC118LL/A Model No: A1286 (EMC 2324*)
Subfamily: Mid-2009 15" Model ID: MacBookPro5,4
Std RAM: 4 GB Std VRAM: 256 MB
Std Storage: 250 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
por
No, but I think this is it (mine has a 2.8 Ghz) :
Intro Date: October 14, 2008 Disc Date: March 3, 2009
Order No: BTO/CTO Model No: A1286 (EMC 2255)
Subfamily: Late 2008 Model ID: MacBookPro5,1
Std RAM: 4 GB Std VRAM: 512 MB*
Std Storage: 320 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
por
Kevin, check the EMC number on image #1 it shows EMC 2324. you sure about the EMC 2255?
por
Exibir mais 2 comentários
Adicionar um comentário
1 resposta
Solução escolhida
Kevin, for the EMC 2324 as it shows on the images you uploaded, the LCD backlight driver has reference designator U9701. It is a LP8543SQX manufactured by TI. the datsheet is available right here. The part itself seems to be a bit hard to come by, but it is available :-) Hope this helps, good luck.
Imagem
Esta resposta foi útil?
Pontuação 4
3 comentários:
Thank you very much for your help.
por
where can I get the replacement piece? thanks
por
Adicionar a sua resposta
Kevin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 19
Ao todo: 25,277
