Ir para o conteúdo principal
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Perguntas Visualizar todos
Pergunta encerrada
Identify part that fell out when repairing
After following the step by step instructions on replacing broken glass a small silver piece and circular part fell out. It has the letters h-f on it. Can you tell me what this is and where they belong?
It fell out right after step 6. when I disconnected ribbons 1,2,3. and removed the glass from the mother board.
A larger view of the part.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Post an image of your part with your question. It will make it a lot easier to identify.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Hello! It is the "MIC" of iPhone 3G. Show u as below pictures.
It belongs to complete dock assembly replacement. So I think you need to replace this spare part.
Here is the replacement part , http://bit.ly/1bLJiwc . You can know more at this website.
Hope will help you.
Esta resposta foi útil?
Pontuação 1
can you make the picture bigger?
Pontuação 0
2 comentários:
also you didnt mention at whatpoint it fell out
por
I cant find a place for it either, could it have come from somewhere on the broken glass screen? I would try finishing the repair as normal and seeing if it works then troubleshoot it from there. If it turns on, check all the settings and buttons and make sure they are working.
por
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 93
