Ir para o conteúdo principal
The fifth Google Nexus phone. Officially announced on October 31, 2013, it sports a 4.95" 1080p display, a 2.26 GHz Snapdragon processor, and LTE support. Powered by Android 4.4.2, KITKAT. Manufactured by LG.
battery physical size (in relation with LG G2)
Hi,
may you confirm the physical size of the Nexus 5 is identical to this one of the LG G2?
Is it technically possible to buy the silicon battery of the G2 (3000mah) and install it in the N5 (same connector, same voltage aso)?
Esta é uma boa pergunta?
Pontuação 4
2 comentários
I'm also looking for an answer to this as I'm looking to purchase this-->http://www.smavtronics.com/3000mah-bl-t7...
por
Adicionar um comentário
3 respostas
Pergunta mais útil
I4U, no you can not. The batteriy are different sizes
LG G2 BL-T7 size 55mm wide X 67mm long
Nexus 5 BL-T9 size 57mm wideX 60mm long
and the battery cable is on a different position.
Esta resposta foi útil?
Pontuação 3
I don't know about the physical size but looking at the LG G2 user teardown and the Nexus 5 featured teardown:
  • Nexus 5 battery reference is BL-T9
  • LG G2 battery reference is BL-T7
  • mAh's are different
  • Finally the battery connectors looks not at the same places
I think we can conclude that you can't install a G2 battery on a Nexus 5, sorry. However, there is Nexus 5 batteries available on internet. Look for "LG BL-T9" on google and don't miss the Nexus 5 Battery Replacement guide on iFixit.
Imagem de Nexus 5
Guia
Nexus 5 Teardown
Nível de dificuldade:
Moderado
Imagem de LG G2
Guia
LG G2 Teardown
Moderado
30 minutes - 1 hour
Imagem de Nexus 5 Battery
Guia
Moderado
20 - 40 minutes
Pontuação 1
the size seems to be different
Pontuação 0
Adicionar a sua resposta
I4U será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 6,385
