Ir para o conteúdo principal
Nexus 5 Battery Replacement
O que você precisa
  1. Nexus 5 Battery Replacement, Back Cover: passo 1, imagem 1 %32 Nexus 5 Battery Replacement, Back Cover: passo 1, imagem 2 %32 Nexus 5 Battery Replacement, Back Cover: passo 1, imagem 3 %32
    • Use a plastic opening tool to free the clips on the top and each side of the back cover.
    • The bottom is secured with some adhesive foam. You should be able to finally free the back cover using an opening pick. The "snaps" at the bottom edge are more like hinges, so release all others then swing the back cover off outward from the top, and these fasteners will release without breaking.
    • It's best to avoid prying around the SIM card slot and volume controls, as the plastic in these areas is very thin and likely to break from prying.
    • When you replace the cover, there is a snap about even with the flash window that must also be attached (one of three that secure the back cover to the midframe). Qi (wireless) charging may not work if this isn't secure. Apply gentle but firm pressure over the "S" in "Nexus" and slide your thumb up towards the top, and the snap will engage.
    Pergunte ao FixBot
  2. Nexus 5 Battery Replacement, Midframe: passo 2, imagem 1 %32
    • Remove the six 4.0 mm Phillips #00 screws that secure the midframe to the phone.
    • Ensure you retain all six of the 4.0mm screws! These hold the midframe securely and closely to the motherboard. The three small snaps on the back cover that attach to the midframe ensure the NFC antenna and wireless charging coil connectors contact securely with the motherboard, and work reliably.
    • To replace the LCD screen and digitizer, remove the additional four 4.0mm daughterboard cover screws with the same screwdriver. You may have to pierce through clear adhesive material to remove them.
    Pergunte ao FixBot
  3. Nexus 5 Battery Replacement: passo 3, imagem 1 %32 Nexus 5 Battery Replacement: passo 3, imagem 2 %32
    • Remove the midframe from the phone.
    • Examine the midframe and the back cover and you'll find three very small snap attachment points for the back to the midframe. These ensure that the NFC and wireless charging antenna contacts connect with the corresponding spring connectors on the motherboard. Ensure the snaps are in good condition.
    Pergunte ao FixBot
  4. Nexus 5 Battery Replacement, Battery: passo 4, imagem 1 %32 Nexus 5 Battery Replacement, Battery: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    Spudger
    $2.99
    • Use the flat end of a nylon spudger to disconnect the battery connector.
    Pergunte ao FixBot
  5. Nexus 5 Battery Replacement: passo 5, imagem 1 %32 Nexus 5 Battery Replacement: passo 5, imagem 2 %32
    • Use the flat end of a spudger to disconnect the daughterboard ribbon cable and pull it away from the battery.
    Pergunte ao FixBot
  6. Nexus 5 Battery Replacement: passo 6, imagem 1 %32 Nexus 5 Battery Replacement: passo 6, imagem 2 %32 Nexus 5 Battery Replacement: passo 6, imagem 3 %32
    • Use a plastic opening tool to pry the battery out of its housing.
    • You may need to use a heat gun to apply a small amount of heat to soften the adhesive below the battery.
    • Do not puncture or bend the battery.
    • If replacing the battery, bag the old battery up and recycle responsibly at a suitable location.
    Pergunte ao FixBot
Conclusão
467 outras pessoas executaram este guia.
Gaetan
Membro desde: 12/26/12
9.613 Reputação
Autoria de 18 guias
67Comentários do guia
I have made this guide based on good quality teardown pictures. I run out of detail pictures for step 3 & 4. Feel free to upgrade the guide if you have a Nexus 5 open and a camera on your hands.
Gaetan - Responder Compartilhar
Did it in less than 10 mins..
Already had experience with taking the backcover off...
Davor Bertovic - Responder Compartilhar
In the start of the guide it says "Replace the battery in your iPhone 5s"
Thomas Novin - Responder Compartilhar
After battery replacement my wireless charging was not working. Pay attention to settle holding clip in the middle of phone - just firmly press around the "S" from the back of phone until you hear it clicks in.
nextsux - Responder Compartilhar
Thank you so much for this tip! I did it and it worked. Now Wireless charging is working again.
QNZ - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 11
Últimos 7 dias: 32
Últimos 30 dias: 158
Ao todo: 349,877
