Ir para o conteúdo principal
O Furby foi um brinquedo robótico eletrônico popular, semelhante a uma criatura híbrida de hamster e coruja, que passou por um período como o brinquedo "obrigatório" após o seu lançamento na temporada de festas de 1998, com vendas contínuas até 2000. Foram vendidas 1,8 milhão de unidades em 1998, 14 milhões em 1999 e, ao todo, nos seus três anos de produção original, os Furbies venderam mais de 40 milhões de unidades.
How to clean battery terminal corrosion
Hi I just found my two 1998 Furbies. They both look great on the inside however they have corrosion and I can't get them to work. Any ideas?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
5 respostas
Solução escolhida
Erikka Holderness, corrosion should usually clean of with a vinegar/sterile water solution. Use a cotton swab or soft toothbrush to clean the contacts. Rinse with sterile water after that, you may have to repeat this step a couple of times. Once it is properly cleaned, use 90%+ isopropyl alcohol to displace any left over water (depending on where the contacts are situated). Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Ok great thank you p :-) I will be trying this.
por
I usually use a vinegar based rust remover and an old toothbrush. Then brush on some WD40 and let it sit and dry overnight, i dont even rinse anything, just wait for it to soak in and dry
Pontuação 1
CLR also works well on battery corrosion after cleaning with CLR use wd40
Pontuação 1
I use 90%+ isopropyl rubbing alcohol, with a q-tip/cotton swab and a paintbrush. I also have a diamond needle kit, that can scrap off heavy corrosion. Sometimes I'll use an soft toothbrush. Baking soda has abrasive properties, yet it's still gentle on electronics. Apply a small amount to the affected areas of your device, and rub it in to remove stubborn traces of corrosion. Then wipe the surfaces down with cotton swabs or a slightly damp, lint-free cloth. White vinegar or lemon juice also works, Most household batteries contain bases, so acids will neutralize their discharge.
Here is a video that might help with your furby: https://youtu.be/iMfin6TM0dE
Here is another video that might help with your furby: https://youtu.be/dJjl7CvBX2Q
Another video that might help with your furby: https://youtu.be/df9WG38gBLs
Imagem
Imagem
Imagem
Imagem
Imagem
Pontuação 1
Battery acid is reported to be neutralized by white vinegar. A Q-tip soaked in vinegar can be used to remove battery leaking.
Pontuação 0
Adicionar a sua resposta
Erikka Holderness será eternamente grato(a).
Visualizações:
Últimas 24 horas: 11
Últimos 7 dias: 145
Últimos 30 dias: 728
Ao todo: 29,982
