Ir para o conteúdo principal
The HTC Evo 4G LTE is an Android smartphone developed by HTC Corporation to be released exclusively by Sprint.
16 Perguntas Visualizar todos
How to recover internal memory from a completely dead phone.
One day while charging my phone, my EVO LTE turned off and never turned back on. I replaced the battery but still no charge. I figured that the problem might be in the motherboard.
My question is , is it at all possible to remove the internal memory itself and replace it on my new phone to recover the lost data?
Esta é uma boa pergunta?
Pontuação 6
6 comentários
So it dose work oldturkey
por
Hello, accidentally erase your valuable data by ROM flashing, factory resetting, deleting, rooting or others? Of course you can always turn to experts. But it may be very costly. Being safe and trouble-free, Android Data Recovery is a good tool to recover data from Android operating systems—Android 4.0, Android 4.4, Android 5.0, etc. Sim Card data, external storage data and internal storage data are all recoverable.
Android Data Recovery is a user-friendly program for data recovery. Unlike other recovery tools, it covers a wider range of data types, which includes photos, contacts, messages and so forth, and a wider range of android devices.
So, you can try using this secure software to restore data from dead Huawei phone
por
So, from where should I recover my data? and does it recovers all types of data such as pictures, musics and videos?
por
My ASUS zenfone selfie has stopped working permanently. How can I recover my files from it?
por
If my phones motherboard died will i still be able to recover my data..images, videos, etc..
por
Exibir mais 1 comentário
Adicionar um comentário
6 respostas
Solução escolhida
scott, no it is not. At least not for the normal DIY'er. The memory are IC's that are soldered to the logic board. Unless you have a reball station, the proper stencils and plenty of experience you won't get it accomplished.....
Esta resposta foi útil?
Pontuação 3
1 comentário:
Thank you oldturkey, that's what I needed to hear.
por
Actually on the evo lte it is! The internal memory module IS NOT on the motherboard in this case. It's actually separate and runs through one of the ribbons to the motherboard to interface with it. I just found out after switching my motherboard over to a whole different phone, all my files were gone but the phone apps, setting, etc were all mine. I switch back to my old screen and all other items that were separate to the mobo and all my files came back! If you find another motherboard and implant it in your phone you should be good!
Pontuação 2
3 comentários:
That's great news to hear! Ever thought about making a guide for this phone so that others can benefit from your findings?
por
This is untrue. Internal memory is soldered to the motherboard on EVO LTE
por
My VIVO mobile phone is not turning on (matherboard problem), How to recovery phots and videos solve problem
por
Do you suffering the same problem as well? Have no idea about how to get back data from broken Samsung or other mobile phone? I know how it feels like after your phone's screen broke up and you have no backups on your computer or other places. But fortunately, you have met the Android data recovery here, and then you'll be able to restore data from broken or dead Android phone within a few clicks.
Actually, when your Android phone broke down, the most urgent thing is that you lose contacts on your phone and you are eager to recover deleted contacts on it. And sometimes you may have saved lots of precious photos of your family or friends, right? So, as a good Android Data Recovery software, it should have the ability to help recover lost or deleted data like contacts, messages, recover deleted photos from android, or even videos on the broken Android phone within a few clicks. And we're proud of the Android data recovery have added these functions into the program in the latest version. Thus, you can freely get it and start recovering data from broken Android mobile phone systematically.
Pontuação 2
My INTERNAL MEMORY IS DEAD, I CANT INSTALL ANY APP. IT SIMPLY SAYS 'INSTALLATION FAILED' EVEN THOUGH I UNINSTALL AS MANY AS ALL THE APPS, AND I FACTORY RESET, MY THE STORAGE DOESNT SHOW ON THE APP MENU. I NEED HELP PLZ.
Pontuação 1
My yureka is completely dead .and I want now internal backup so wat can I do sir :( plz help me some thoughts
Pontuação 0
Hello,
Data loss from phones is very common. Well, a dead phone denies access to all the stored data in addition to restricting you from making regular phone calls. As a dead phone is of no use, but the data stored within it surely important. So first I will suggest you check your mobile phone with the service center and repair it. But, maybe you lose your data in repair.
Thus, if you want to recover your data, I recommend you to contact the data recovery service provider.
Pontuação 0
Adicionar a sua resposta
scott será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 28
Últimos 30 dias: 90
Duração total: 66,722
