Ir para o conteúdo principal
Released December 3, 1994 in Japan and September 9, 1995 in North America. Models SCPH-100x, SCPH-3000, SCPH-3500, SCPH-500x, SCPH-550x, SCPH-700x, SCPH-750x, and SCPH-900x.
73 Perguntas Visualizar todos
Graphics off at the sony computer entrainment logo can it be fixed?
Hello,
I got a original playstation from a yardsale for 3$ but i got more stuff too with it. i got 3$ in games(1$ each) and 2$ in controllers for it(1$ each)
After using it one day i noticed the sony computer entertainment logo is not fully lined up with other letter tops right and the powersupply gets warm
Whats wrong?
heres more info
AC 120V 60HZ 17W
manufactured MSK YONHENZA JAPAN
December 1997
update
i forgot to mention the person i bought it from said it wasnt uses for years and i only bought the system itsself
if i can fix it is it worth it?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
Try opening it up, then cleaning the dust out of the heatsinks, and casing.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Your power supply will always get warm. Since it is an old gaming system the technology in the supply is not as efficient as todays power supplies.
If there is a slight alteration with the graphics then perhaps the AV cables you purchased are old. Inspect the ports that it is connected to for any broken pins or excessive dirt. If the slight graphics issue poses an annoying problem you could look into testing a different cable.
Pontuação 3
1 comentário:
had the cables laying around unused for a while
only bought the playstation
por
Adicionar a sua resposta
Nick será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 4,306
