Ir para o conteúdo principal
Este Apple Cinema Display é caracterizado pelo número de modelo M8149 e foi lançado pela primeira vez em julho de 2000
top half of screen dark
Dear all,
Can anyone give advice on how to fix the following? I have a Apple Cinema Display M8149 connected with and ADC-DVI adapter to a Mac Pro or MacBook Pro. Some time in the past the top half of the screen suddenly turned low in luminosity, right trough the middle of the screen. It still show an images but darker than the bottom half. So the top-half has half the luminosity of the bottom half. Feels like some fuse issue? Or maybe something else? Can anyone identify this problem and advice how to fix it? I ruled out the adapter (same problem with a new one) and the graphics card (same problem with different computer setup ). All help is appreciated!
Kind regards,
Marcel
Esta é uma boa pergunta?
Pontuação -1
1 comentário
Be careful with what you spend on parts as this thing can be bought for under $80 now.
por
Adicionar um comentário
1 resposta
Solução escolhida
Marcel, sounds like either a bad inverter board or a burned out CCFL. I'd start with the inverter board since it is easier to replace than a CCFL.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Marcel será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Ao todo: 943
