Ir para o conteúdo principal
Também conhecido como LG Splendor, uma encarnação do LG Optimus L7, por vezes conhecido como LG Snapshot ou Swift L7 sob os números de modelo US730 e LG730, dependendo da operadora.
How Do I install a LG730 LCD Display Screen?
I just replaced my screen on my LG730, now I am waiting for my new LCD screen to arrive. I am wondering, how do I install it? I have a rough idea, but never had to do it before. I spent time on the internet and could not find much. Does anyone have advice?
Esta é uma boa pergunta?
Pontuação -1
2 comentários
Well I should have clarified. I Replaced the touch screen, which had a few spider web cracks in it. I also damaged the LCD screen, I do not know how to Take out, and put in the new LCD screen, at least with out damaging anything.
por
Oh nevermind, I did a little tinkering around, and got it all situated, thanks for the help though man, I'll accent your answer.
por
Adicionar um comentário
1 resposta
Solução escolhida
Zack Borgen, I am a bit confused. You said that you replaced the screen, but now you are wondering how to install it. Did you check my answer from here:"
Take apart the battery cover using notch below
Imagem
Take apart the battery and remove screw (12 point)
Imagem
1. Unfastening the hook, make gap between Rear Cover and Front Cover
2. Widen the gap between Rear Cover and Front Cover and hook off starting from below side (back view)
Imagem
1. Take connectors & Side Key FPCB (1~9) out of the Main PCB
2. Widen the gap between Front cover and main PCB
Imagem
3. Remover the Bracket Camera to upper
Imagem
1. Unfastening the hook from below side, sh back side of LCD through a hole on back side of Front cover
2. Take apart Frame out of Front cover
Imagem
1. Lift LCD from the frame & Take off the LCD.
2. Be careful. Do not tear the LCD FPCB
Imagem
Esta resposta foi útil?
Pontuação 1
2 comentários:
I'll take another look at my LCD, but it does not just come off like the instructions show. So I'm sure I'm reading something wrong
por
Thank you for accepting my answer. If you need to take a look at the manual, let me know. My email address is in my profile.
por
Adicionar a sua resposta
Zack Borgen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 1,854
