screen stays bright when off
Screen is white when I power off, and stays on until I remove battery
Esta é uma boa pergunta?
Jerry, its your BIOS that tells the PWM when to turn the backlight off or on.
Try to flash or update your BIOS. Check on here for a BIOS update and how to do it. Hope this helps, good luck.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Ao todo: 284
2 comentários
Your screen is always white? What happens when you turn your computer on? Does the normal data show up on the screen?
por oldturkey03
Yes, everything works normal except for screen problem
por Jerry
