Ir para o conteúdo principal
2,26 ou 2,4 GHz / Estrutura monobloco de plástico branco
Keyboard ZIF Connector Pinout
I'm looking to determine which contact on the keyboard connection on the A1342 is for the 'on' switch function (or any other contacts on the logic board will do). I'm fairly certain this pin is active low (pressed goes to ground), yes?
Thanks, Keith
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Hi,
I am searching for the pinout of 34 pin ffc cable of laptop keyboard.
Thanks & Regards,
Yash Kishore
por
Adicionar um comentário
3 respostas
Solução escolhida
Keith55555, looks like pin 5 is the one you are looking for. Hope this helps, good luck.
Imagem
Esta resposta foi útil?
Pontuação 4
3 comentários:
Looks good O.T. Appreciate it. -Keith
por
Anytime ;-) Thanks for accepting my answer.
por
Do you have a keyboard pin out from an A1502?
por
It boggles my mind that this little picture was so hard to find on the INTERNET it is almost like these companies making laptop er um notebooks these days dont want us knowing how they work or operate.
That way we cannot ever comprehend enough to troubleshoot or fix them when something goes wrong. Or they just dont want us realizing that they are built to fail in so many hours. Grrrrrr
Pontuação 0
I measured the resistance in Ohm of those pins to ground, both keyboard plugged in and (plugged out)
  1. 336 Ω (336 Ω)
  2. 336 Ω (336 Ω)
  3. 337 Ω (336 Ω)
  4. 209 Ω (208 Ω)
  5. 1745 Ω (1745 Ω)
  6. 444 Ω (1.9 MΩ)
  7. 368 Ω (468 Ω)
  8. 365 Ω (1.92 MΩ)
  9. 440 Ω (439 Ω)
  10. 372 Ω (371 Ω)
  11. 369 Ω (369 Ω)
  12. 381 Ω (381 Ω)
  13. 282 Ω (444 Ω)
  14. 477 Ω (477 Ω)
  15. 443 Ω (442 Ω)
  16. 442 Ω (441 Ω)
  17. 442 Ω(441 Ω)
  18. 444 Ω (443 Ω)
  19. 381 Ω (381 Ω)
  20. 441 Ω (440 Ω)
  21. 440 Ω (440 Ω)
  22. 445 Ω (445 Ω)
  23. 442 Ω (441Ω)
  24. 443 Ω (442 Ω)
  25. 440 Ω (440 Ω)
  26. 448 Ω (448 Ω)
  27. 444 Ω (443 Ω)
  28. 444 Ω (444 Ω)
  29. 0 Ω (0 Ω)
  30. 230 Ω (229 Ω)
measured on an MacBook Pro A1502
Pontuação 0
Adicionar a sua resposta
Keith55555 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 54
Ao todo: 7,448
