Ir para o conteúdo principal
A soldagem é uma técnica de conexão de duas peças de metal por meio da fusão de um metal de adição entre ambas. Há muitos processos de soldagem, porém este artigo visa ensinar a você os métodos básicos da soldagem elétrica.
56 Perguntas Visualizar todos
Looking to find out best means to learn soldering techniques
Hi everyone,
Looking to find information on the best means to learn how to solder. Often there are cases with my business I require the ability to solder. I have soldered previously however I find it frustrating when the solder does not stay on the part being soldered. I have read about adding flux and temperatures and a host of other articles which were not helpful.
How did you learn to solder?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
3 respostas
Solução escolhida
This is kind of like asking, "how do you ride a bicycle". Practice, practice, practice.
Start here: Soldering
Solder
Solder is used to create a non-permanent electrically conductive connection between non-ferrous metals. The relatively low melting point of lead/tin (Pb/SN) solder is a perfect match for sensitive electronic components. For applications where lead is not desired, one good substitute is "no lead" solder - usually a mixture of tin with a trace amount (0.3%) of copper. Note that most so-called "silver solders" are lead/tin with about 2% silver added. Lead-Free Solder
Stuff you may need: Soldering Workstation
Como soldar e dessoldar contatos
Here's some more extensive reading on it: http://www.instructables.com/id/How-to-s...
Imagem de Lead-Free Solder
Produto
Lead-Free Solder
Imagem de Soldering Workstation
Produto
$49.99
Esta resposta foi útil?
Pontuação 3
Utube
Pontuação 0
Thanks Brian.. Never thought of that..
Pontuação 0
Adicionar a sua resposta
new2usedcomputers será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 601
