Ir para o conteúdo principal
Tudo que você precisa para reparar por conta própria o seu iPhone! A iFixit tem guias de reparo gratuitos e informações de desmontagem para cada um dos modelos iPhone, assim como as melhores peças de reposição e ferramentas da galáxia!
Hardware diagnostics service software
Hello,
I started a little bit trading with iPhones. Is there any way how can I make hardware check - diagnostics of problems by some software?
And what repair services use when they provide "diagnostics" service.
Thank you
Esta é uma boa pergunta?
Pontuação 16
3 comentários
my iphone 6 shut off just like that and now it only comes on when i plug the cable in, but this the logo come on and then cuts off. i started it up in dfu mode and restored it but its just saying error 4005. what should i do?
por
My iPhone 6 Plus has problems, I try and touch the screen sometimes and it doesn’t work, and when I try to download something it shuts off the iPhone and restarts it and all the other iPhones dont have these problems, my iPhone has many more problems to
por
@Robin Mason This topic is not what you want to ask.
por
Adicionar um comentário
4 respostas
Solução escolhida
radesek, here is my answer to a very similar question:" You could check on here and see if that will help you a bit. "It’s called the iPhone Configuration Utility, which allows you to examine logs from your iPhone or iPod Touch, to apply configuration and provisioning profiles, and more. The tool is very interesting!" from here I believe the software you are thinking of is called "Behavior Scan" More info about it on here and here. I would also like to recommend the iPhone Troubleshooting Guide compiled by one of the users on here. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 2
6 comentários:
Thank you, but I already read this information. The problem is, that I think iPhone Configuration Utility is not exactly what I am looking for and that Behavior Scan somehow cant be accesed without login of Apple employee right?
I need software that will test hardware things like working wifi, camera, jack and stuff like this. Is it possible?
por
Can be this a sollution? Problem is I can not be sure with it, since my iphone does not have panicplist entry.
por
I do not think that there is any diagnostic software that is available for an end user, that will tell you exactly what is wrong with the iPhone. That would be to easy;-) From what I've read if your phone shows panic.plist. then you may have a hardware error, not very descriptive.
por
Where to look for that panic.plist file?
por
is there any point having a website with all dead links
por
Exibir mais 1 comentário
Phone doctor plus in the app store, however contact the developer for business solution.
Pontuação 1
I'm using Battery Health - Your Battery Doctor app in the app store, very nice app
Pontuação 0
Hello, my company uses NSYS tools. It’s quite easy to use and accessible.
Pontuação 0
Adicionar a sua resposta
radesek será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 35
Ao todo: 117,779
