Where exactly is the Flasher Relay for a 2003 Mazda Protege located?
Esta é uma boa pergunta?
Berry, the Turn signal/Flasher relay is under dash on drivers side. If you have a manual transmission is is almost directly above the clutch pedal. It is a gray colored box about 2 inches wide by 4 inches long. It is #5 in the attached diagram.
Hope this helps, good luck.
Esta resposta foi útil?
Thank You very much , it solved my problem.
Thanks
Ronald (Philippines}
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 45
Duração total: 11,299
1 comentário
Thanks oldturkey03! I will check this out immediately.
por Berry
