Ir para o conteúdo principal
Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
Flickering backlight... how do I fix it?
I just finished assembling a new front display (LCD and digitizer) on my Verizon iPhone 4 because I had a cracked screen. Everything works great, except the backlight on the screen seems to be flickering...it's very subtle, but soon it will start to drive me crazy Does anyone know why this might be, and how I could go back and fix it?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
try turning off the auto brightness.
if that didn't work you have no other option than replacing it. it a common fault on these copy's
Esta resposta foi útil?
Pontuação 1
1 comentário:
Yep: my aftermarket replica screen had flickering/pulsing brightness. Over one month of use did not magically break it in or burn it in. Auto-Brightness has nothing to do with it, in my instance. I replaced this copy with a used Apple original, and problem is gone. It was just a lousy copy.
por
Adicionar a sua resposta
Katie será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 4,089
