Ir para o conteúdo principal
Os fones de ouvido estéreo com subwoofer Skullcandy Skullcrushers em Black Pinstripe vão literalmente bombear a música direto para a sua cabeça! Esses fones de ouvido potentes possuem um amplificador de graves no cabo ajustável e alto-falantes eletrodinâmicos com subwoofers vibratórios embutidos, os primeiros do setor. Você pode ajustar a intensidade do efeito dos graves com a roda de controle no cabo.
both subs are not working
When i move the wires around they go on and turn off when i move it and i have opened them up and every thing looks fine i do not no what to do.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
Adam Thompson,"i move the wires around they go on and turn off when i move it" indicates either a bad solder connection or broken wires. You have not told us where you wiggle the wires to make it work. If it is by the audio connector, replace it using this guide. If it is by the bass amplifier, open it up and take a look at the solder connections on there. I attached a few images that should help you to identify the wires and connections.
Imagem
Imagem
Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 3
2 comentários:
i am moved the wires where the speakers connect i have looked where they connect there and it looks to have no connection problems there
por
Sounds like a bad bass amp. Check the components on there with a multimeter and see if you can figure out what failed.
por
When I had the same problem as stated above, I often had to tap on the head phone that had the bass control installed to bring the bass back to my normal listening level. I finally decided to see if I could re-mediate this problem for once and for all. I remove the amplifier and re-soldered the bass control tabs, the eighth inch audio input jack tabs and the cable wires that connect to the amplifier board. Now the bass does not drift in and out when I'm listening to music.
Pontuação 1
Adicionar a sua resposta
Adam Thompson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Ao todo: 4,493
