Ir para o conteúdo principal
Os fones de ouvido estéreo com subwoofer Skullcandy Skullcrushers em Black Pinstripe vão literalmente bombear a música direto para a sua cabeça! Esses fones de ouvido potentes possuem um amplificador de graves no cabo ajustável e alto-falantes eletrodinâmicos com subwoofers vibratórios embutidos, os primeiros do setor. Você pode ajustar a intensidade do efeito dos graves com a roda de controle no cabo.
The left side of subwoofer
Hello i have to repair the left side of subwoofer in skullcrushers, and there is a question:
the subwoofer has 4 slots:
"LV+"
"LV-"
"RV+"
"RV-"
which of them should be paired with following cables:
"red-blue"
"red-gold"
"Green"
"blue-gold"
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 2
2 comentários
Perhaps you could take apart the right side and see which ones match there (from my experience in audio, they should be exactly the same)? Bonus Internet points if you make a guide for it :)
por
Adicionar um comentário
1 resposta
Solução escolhida
bartek94to, attached image is what I come up with on the opposite end. Hope this helps, good luck.
Imagem
Esta resposta foi útil?
Pontuação 2
4 comentários:
I did it like you had wrote me. But i can't even hear any bass : | maybe this subwoofer is just broken
por
Try to bypass and go right for the speakers. See if that makes a difference.
por
i don't realy know what do you mean : p and i am sure that i couldn't do that, cuz i am novice : | Have you got skype?
por
Try to bypass the amp. You will need the end that comes from the jack. See the repair 3.5mm jack on the device page Reparo do plugue de 3,5 mm do Skullcandy SCS-SCBP SKULLCRUSHERS Connect Gold, Blue Gold RV- and LV- Red/Green to ground, L+Blue and LV+Green to the left, and R+ Red and Red/Gold RV+ to the right. sorry, can't Skype until I get off work. My Skype ID is in my profile.
por
Adicionar a sua resposta
bartek94to será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 23
Ao todo: 1,318
