Ir para o conteúdo principal
A Sony Cyber-shot DSC-W55 foi lançada no início de 2007. Ela é uma versão aprimorada com uma câmera de 7,2 megapixels, em comparação com a câmera de 5,1 do modelo anterior, e possui 56 MB de memória interna.
Flash does not work!
Turned camera on and heard a loud pop. Removed and charged NP-BG1 battery. Reinstalled charged battery, but battery discharged rapidly. Bought new NP-FG1 battery, charged battery, installed battery and got "E91:01 error code with flash symbol flashing on LCD screen. Camera takes pictures, but flash does not flash. I suspect the capacitor blew when the loud pop was heard. Any suggestions?
Where can I buy a replacement capacitor without buying the entire flash unit?
THANKS in advance.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Dick, the error code that you are getting is related to an issue with the flash or light on your camera. There are a two things that may have made that noise, Either your flash bulb, or your flash capacitor. Follow [http://he error code that you are getting is related to an issue with the flash or light on your camera. It's usually just replacing the flash bulb on the camera,|this guide] to either replace the capacitor or the whole assembly. the part numbers are as follows:
1-479-663-31 FLASH UNIT
1-112-819-11 ELECT 97uF 315V Capacitor
you can get it from here
A-1231-877-A ST-133 BOARD, COMPLETE
Imagem
Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 2
3 comentários:
THANKS "oldturkey03", I plan to disassemble the camera and investigate further this week. Dick
por Compartilhar
На плате st-133 посмотри контакты конденсатора и детали которая распаяна под лампой . Может и в самом конденсаторе дело ! Тратить надо ...
por Compartilhar
сперва саму батарею проверь . а потом дальше ...
por Compartilhar
Adicionar a sua resposta
Dickie será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 22
Ao todo: 2,303
