Ir para o conteúdo principal
Manuais de reparo e informações para a linha de tablets Microsoft Surface.
Can I upgrade RAM?
just it, im wondering if ram memory can be upgraded...cause today 4gb may be enough...but i cant say that next year it will.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Can you replace the memory , it is not limited by the OS, isn't?
por Compartilhar
Adicionar um comentário
3 respostas
Solução escolhida
No, I am afraid not. The 4GB in the system is currently integrated into the board to save space and there are no available slots to connect more RAM. Please refer to the excellent tear-down iFixIt has provided and scroll to set 14 to see the board itself for further insight as to its makings.
Microsoft Surface Pro Teardown
Esta resposta foi útil?
Pontuação 5
No, sorry it can't be upgraded. I took it to US and tried at Best Buys and couple of other shops. All advised, use it till battery is dead, or as replacement to mobile phone for watching y-tube clips :-)
I am precisely doing so.
Pontuação 0
You may not be able to upgrade the ram directly, did you try to add a page file or swap to it so it can use storage for extra ram?
Pontuação 0
Adicionar a sua resposta
Gaston Nuzzolese será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 24
Ao todo: 36,403
