Ir para o conteúdo principal
Repair information for the 6th generation iPod nano. Released in September of 2010. Model Number: A1366.
175 Perguntas Visualizar todos
Please help me! WATER DAMAGE
I accidentally washed My iPod in the washing machine and it wouldn't turn on. I put it in a bag of rice for 24 hours but nothing happened. when I took it apart the lcd fell apart. Please tell my how to fix it
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
chanan, It seems this happens a lot. Here is my answer to the same question from a different person "The first step you should do is to disassemble your iPod. Use this guide to help you out. After that clean the iPod thouroughly by following this general guide. You a high grade isopropyl alcohol. Once you are sure the logic board, connectors (do not forget the dock connector), and cables are clean replace the battery. You can get it at places like this. Once you have all this accomplished, reevaluate for any residual (if any ) damage. In your case, you may have to replace the LCD as well. Follow this guide for that. Remember that this model is a PITA to work on but not impossible to fix. Hope this helps, good Luck.
here and here and one more here
Imagem de iPod Nano 6th Generation Front Panel Assembly
Guia
iPod Nano 6th Generation Front Panel Assembly Replacement
Nível de dificuldade:
Moderada
35 minutes - 1 hour
Imagem de iPod Nano 6th Generation Logic Board Assembly
Guia
iPod Nano 6th Generation Logic Board Assembly Replacement
Moderada
30 minutes - 1 hour
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
chanan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 9,258
