Ir para o conteúdo principal
Pergunta encerrada
What order do I go in to replace these parts?
Hey all, thanks in advance.
I'm going to replace the right and left fan, harddrive and RAM on my MBP A1212. Is there a particular order I should follow as far as which part to put in first, second, and third? Thanks!
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Thank you very much! Just replaced all those parts yesterday with no hiccups.
por
Adicionar um comentário
1 resposta
Solução escolhida
I would do fans, then hard drive, and end with RAM. You don't need to remove any of these items to replace the others, but you do have to remove the left i/o board to get to the left fan, so might as well start with the hardest step first.
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 244
