Ir para o conteúdo principal
Segunda geração do Ford Focus.
Where is the wiper relay?
My wipers recently went out on my Focus. I have checked voltage at the wiper motor and have DC coming in on all wires but the black/white. It's either due to a bad wiper relay or the wiper/washer switch. I would like to check the relay before breaking into the steering column, but I cannot find it. The wires go into the distribution box, but I cannot find out where. The web has advised the relays are under the dash, but they are not.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Pergunta mais útil
danielelphinstone, check the fuse box under the hood. The relay is attached to it.
Imagem
Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
You find here a fuse box description and diagram for Ford Focus
Europe version
http://www.autogenius.info/en/ford-focus...
USA version
Pontuação 0
My wipers went out on me, as soon as I turned my car off. I would like to know, What's the number on the fuse for my wipers. On a Ford Focus, 2007.
Pontuação 0
Adicionar a sua resposta
danielelphinstone será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 46
Ao todo: 29,436
