Ir para o conteúdo principal
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
20 Perguntas Visualizar todos
How do I know if my SP is getting charged?
How long does it take for a Game Boy Advance SP to charge and does it have any lights that stay on or flicker to indicate charge? because when I plug in the charger to my SP an orange light will flicker only once then turn off. Is my SP broke?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Rosie Pacheco, sound like you are either not getting a charger, or your battery is no longer accepting a charge. Check your charger with a multimeter to see that it does supply power. Take the back cover off to expose the charging port. With the charger plugged in, you should get around 6V at the port. Then check the voltage on the battery ports and see what you get. If so, it may be time to change the battery and then re-evaluate. Check this video on how to change the battery. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Rosie Pacheco será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 47
Duração total: 10,733
