Ir para o conteúdo principal
The Sony Ericsson W810i is a Walkman mobile phone with a camera and music playing capabilities.
6 Perguntas Visualizar todos
Pergunta encerrada
Only turns on when plugged into charger just flashes sony screen
My w810 won't turn on I think it is because for one it won't charge and second when I plug it in to charge it only gets to the sony ericsson screen then resets doing it over and over I have tried to connect to the pc to reflash but it won't recognize it poped up once could not recognize but never again I think it's because it had just a thread of charge left in the battery I think it's a hardware issue i'm wondering if there is something I can do any help would be much appreciated thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
crayzze, the reason for not charging could be a bad battery. Start by replacing that one, follow this guide. Make sure that you charge port is in good working condition, and that no debris or corrosion is present. Try a different cable as well. With a new battery, at least you will have a known good starting point should further troubleshooting be necessary.
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,506
