Ir para o conteúdo principal
Sony Ericsson W810I Battery Replacement
  1. Sony Ericsson W810I Battery Replacement, Battery: passo 1, imagem 1 %32
    • Place your Sony Ericsson W810I screen side down with the battery cover facing up as shown.
  2. Sony Ericsson W810I Battery Replacement: passo 2, imagem 1 %32
    • Remove the battery cover by applying downward pressure on the Singular Symbol and then shifting the pressure towards the bottom edge of the phone.
  3. Sony Ericsson W810I Battery Replacement: passo 3, imagem 1 %32 Sony Ericsson W810I Battery Replacement: passo 3, imagem 2 %32
    • Lift the bottom of the battery away from the phone with your thumb and rotate until the opening in the bottom of the case is oriented downward. The battery should slide out.
Conclusão
Lucy Bowen
Membro desde: 09/01/11
473 Reputação
Autoria de 7 guias
Equipe
Cuesta, Team 1-7, Zipperian Fall 2011 Membro de Cuesta, Team 1-7, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G7
1 Membro
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 24
Últimos 30 dias: 97
Ao todo: 8,535
