Ir para o conteúdo principal
MacBook Pro No Power at all
I just brought a used MacBook Pro and brought a magsafe adapter from apple store. plugged it in and get no power. no light, only on the magsafe. Battery will charge, just no power. Any thoughts?
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
2 respostas
Solução escolhida
Try resetting the PMU and PRAM and let me know if that helps. Ralph
http://support.apple.com/kb/HT1431
http://support.apple.com/kb/HT1379
Esta resposta foi útil?
Pontuação 4
3 comentários:
Neither of those worked.
por Compartilhar
It begins to look like a board problem. Is there any chance of you being able to return it and get your money back? Ralph
por Compartilhar
no but thanks i might buy a board
thanks again
por Compartilhar
I can show you how to open the back and boot it from the board. Sounds like the computer has power but the keyboard had liquid spilled into it and stopped working. The easiest way to find out is remove the bottom panel and boot from the pads on the logic board with a pair of tweezers. I fix liquid spilled mac's everyday. If you can send me some more info on your computer I can send you step by step photos.
Update
Imagem
sorry its a bit blurry, I need a real digital camera! ANyways, these are the power pads on a 17-inch. The reason I asked you for logic board serial was so I could determine for you (and send you an image) of the correct pads. Apple in the service manual says "short the two pads together" and the easiest way is with a pair of tweezers.
Pontuação 0
2 comentários:
I'd be really interested in a made guide by you Josh about booting from the pads on the logic board with a pair of tweezers. What are you going to do with your old logicboard ?
por Compartilhar
oh so on all logicboards it will read pwr btn?
por Compartilhar
Adicionar a sua resposta
pcwcomputer será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 8,880
