web cam for iBook g4 1.33
Hey there. I tried to connect regular window's webcam , it didnt work. So tell me , please, do i need some special web cam or i do something wrong in connection?
thank you . Mike
Esta é uma boa pergunta?
Cancelar
thank you . Mike
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa LojaYour best bet is a used Firewire iSight camera, simply because of compatibility; these are also commonly available despite being discontinued for years.
If you do not wish to get a used camera, there are USB webcams that work with OS X but they tend to be few and far between. Try and find one that's advertised to work otherwise it's a gamble and you may not be able to return it if it doesn't work for you.
The Macally IceCam2 webcam works pretty well with my daughter's iBook G4 1.33Ghz under OSX 10.5.8. It's a USB 2.0 webcam so it won't work with Macs using the old USB 1.0 technology.
To use iChat (or any other video chating software), you need a FireWire 400 webcam (Preferably an Apple iSight) and a FireWire 400 port (Which your laptop should have). External USB webcams are not supported in Mac OS X.
Rep: 1
Any webcam that is UVC (USB Video Compliant) should work. You will need to be using at least OS 10.4.9. Personally I use a Logitech, QuickCam Deluxe for Notebooks, and it works fine. But be carefully, older versions of the Deluxe model do not support UVC. Look for a model that is VISTA compliant, that should also be UVC compiant. You may want to pick up a copy of iGlasses, the software will give you a lot of control over the webcam image.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Todo: 4,333
