My iPad screen is parshly green.
You can still see my lock and home screen, but its covered in green. Any body know how to help?
Esta é uma boa pergunta?
Hi just disassemble your ipad and disconnect your lcd cable, then reconnect it back, did this happen after a fall?, most probably the connector is loose or worst its the lcd cable, hope that helps cheers!!
Esta resposta foi útil?
Hi have you tried the solution i suggest to you?, btw just for future use, try to tape the lcd connector point so that it does not come loose again, cheers!
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 401
