Ir para o conteúdo principal
Pergunta encerrada
My iPad screen is parshly green.
You can still see my lock and home screen, but its covered in green. Any body know how to help?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Hi just disassemble your ipad and disconnect your lcd cable, then reconnect it back, did this happen after a fall?, most probably the connector is loose or worst its the lcd cable, hope that helps cheers!!
Esta resposta foi útil?
Pontuação 0
Hi have you tried the solution i suggest to you?, btw just for future use, try to tape the lcd connector point so that it does not come loose again, cheers!
Pontuação 0
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 401
