Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2201 Perguntas Visualizar todos
Pergunta encerrada
How do I reconnect the display cable on an iPhone 4s?
I dropped my Iphone on tile floor (bottom left corner of Iphone) and now it's got a green-ish hue to the display as well as some weird lines. When I first open it up it looks normal for about 2 seconds and then that lovely shade of green comes up and stays. I've heard it may be a loose display cable but how do I go in and make it more secure?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Ashley, start by using this guide. Check your connector and your cable. If it is seated properly and if the connector is okay, I would think about replacing the display. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 2
1 comentário:
This looks like a guide to replace the actual display screen. I'm looking to secure a loose display connection within the phone (wherever that may be!) Appreciate the help!
por
A little bit slower: Ashley, START by USING this guide
Pontuação 0
1 comentário:
easy now... no need to belittle someone
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 13,687
