Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2396 Perguntas Visualizar todos
front camera stuck on shutter after screen repair
no i did it! broke of a small component on top of the motherboard. its the one responsible for the front camera. after some diggin' on the internet i found out that it can be fix by making a small bridge. tried it but it didn't work because the pads are missing. solder just didn't take.
as you can see in the picture, there is still some copper left.
tried putting some conductive glue on there but still nothing.
is there a way to fix the pads or does anyone know what points to wire connect so the part is briged
any tips are welcome
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Hi, can u pls circle what it is that u r trying to repair. I just opened mine up and didnt see anything different. Maybe I am looking at it wrong.
Edit: Saw it now, the capacitor. Are u sure that bridging it will be ok? Do u have a 1nf ceramic disc lying around? Try using that, and if it works then just order a 1nf smd. Seems like there is enough contact. As far as alternate solder points, I dont think there is a schematic for the motherboard, I maybe wrong. If u do find one, pls attach a link here. Thanks.
por
Adicionar um comentário
2 respostas
Solução escolhida
Hi,
Try this:
Sorry for the bad quality of pic.
Esta resposta foi útil?
Pontuação 3
3 comentários:
thank you for the quick response, i will give it a try and post result here
por
yes it works! thanks again!
por
can i ask what the heck your picture is referring to?? you've got a blue line drawn clear across the motherboard.
i understand you're supposed to bridge these two dots as clearly seen in the first photos.
por
I have the same issue with my iPhone. Could someone walk me through what I'm meant to do regarding the picture above?
Pontuação 0
2 comentários:
Solder a thin wire between this two points.
por
Thank you for answering. I apologize for being so newbie! But do I have to remove the existing capacitor before I make the installation? Or can i just solder it right on top of it?
Thanks again!
por
Adicionar a sua resposta
ifixshop será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 2,513
