front camera stuck on shutter after screen repair
no i did it! broke of a small component on top of the motherboard. its the one responsible for the front camera. after some diggin' on the internet i found out that it can be fix by making a small bridge. tried it but it didn't work because the pads are missing. solder just didn't take.
as you can see in the picture, there is still some copper left.
tried putting some conductive glue on there but still nothing.
is there a way to fix the pads or does anyone know what points to wire connect so the part is briged
any tips are welcome
Esta é uma boa pergunta?
1 comentário
Hi, can u pls circle what it is that u r trying to repair. I just opened mine up and didnt see anything different. Maybe I am looking at it wrong.
Edit: Saw it now, the capacitor. Are u sure that bridging it will be ok? Do u have a 1nf ceramic disc lying around? Try using that, and if it works then just order a 1nf smd. Seems like there is enough contact. As far as alternate solder points, I dont think there is a schematic for the motherboard, I maybe wrong. If u do find one, pls attach a link here. Thanks.
por John Savio
