Ir para o conteúdo principal
Lançado por volta de 2010, o Dell Inspiron 15R N5010 é um laptop de 15 polegadas com processador Intel e placa gráfica ATI Radeon dedicada.
My laptop cannot get started.
My Dell inspiration N 5010 just cannot get started. When I plugged in the power and press the start key, nothing happened, no reactions at all. No sound. Then I took out the battery and plug in the source cable again, still nothing at all. I notice that when connected to the power source, the light on the adapter was on. But as soon as plugged into the laptop, it went off immediately. I also tried other adapter but the very same thing happened. My question is what was wrong with my laptop,and how I can fix it myself. Someone says it has something to do with the mother board but I am not sure. Please help me with this issue. Thank you.
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
4 respostas
Pergunta mais útil
Xu Sun, since you already tried different AC adapters you can most likely rule it out. I would first check the DC plug on your motherboard. Make sure it is properly connected and that it does get power. Check the connectors for any broken solder etc. To work on your laptop, get the service manual from here.
Esta resposta foi útil?
Pontuação 1
5 comentários:
Thank you oldturkey. Since it is my first time trying to fix a computer by my hand, could you please be more specifically such as give me some more detailed directions? How can I check the DC plug to see whether it is well connected, and what should I do then?
por
Do you have a multimeter? Check this video. Hope this helps.
por
I do not have one at the moment, and how come the page for the video is about iPhone replacement battery? Sorry to bring you so much trouble but I still want to figure it out.
por
Sorry for the wrong link this is the one I was referring to.
por
Hi oldturkey, I have disassembled my laptop and tested the power jack. When I plugged in the adapter, I used the multimeter to test the voltage received from the power jack, and it was about 200 mV or so, far below the 19V which was needed. Now does it mean the problem was on the power jack? And if it is, how can I fix it myself?
por
There is power supply chip in the motherboard which handles every power related things inside motherboard like charging display power supply. If there is any problem with anywhere related with power things this chip won't let it on and same thing is happening. So there is power supply chip problem.
Pontuação 1
2 comentários:
Vergo, please read the comment by Xu Sun (the OP0, November 13, 2012 A clear indication that it is not the PMIC. BTW, this question is over 2 years old.
por
Hi! I have the same problem. I switched on my computer and it came to the windows login screen and it suddenly switched off. It was not connected to power at that point. Do you have any suggestions?
por
Something else you may want to try. I had an issue where I'd press the power button on my Inspiron N5010, the light would come on, then immediately go off. No POST, no Dell slash screen. I replaced the I/O board and same symptoms. Next I replaced the motherboard and the same symptoms occurred. I had already removed ram, CD, HDD, etc., and nothing. As a last ditch effort I removed the keyboard and plugged in a usb keyboard. And that my friends solved the issue in my case. Ordered a new keyboard, installed it, and everything appears to be working fine now. I wanted to post this just in case someone else has had the same issue and hadn't tried testing the keyboard.
Pontuação 0
Its probably your DC jack has some off or got dry soldered from mother board but if you care confident about the DC jack is fine then you may can try by cleaning your motherboard with isopropyle alcohol and gently dry it at distance by using some hair dryer.
Pontuação 0
Adicionar a sua resposta
Xu Sun será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 32
Ao todo: 12,424
