Ir para o conteúdo principal
Pergunta encerrada
shows apple logo and turns off when turned on.
shows apple logo and turns off when turned on.Will a battery replacement solve this problem?
http://www.ebay.com/itm/New-Battery-3-7V...
Will the battery shown in above link be long lasting?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Hi, will ur ipod boot up and play with no problems when connected to a dock or the computer? If it does then replacing battery will do. As far as battery longevity, that will depend on how u use it and charge it. Hope this helps. Write back on what u did. Good luck.
por
I really forgot to mention an important thing.This logo comes and goes off when plugged to my pc. Ipod doesn't turn on at all without plugging it.
por
Adicionar um comentário
1 resposta
Solução escolhida
Hapan, sure sounds like a bad battery to me. I would start with that. If nothing else it will provide you with a known good starting point for further trouble shooting. You'll find the guide for that on here. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 588
