Ir para o conteúdo principal
Modelo menor, mais fino e mais silencioso do PlayStation 2 (SCPH-700xx) lançado pela Sony em setembro de 2004.
PS2 slimline no power.
Accidentally inserted wrong power adapter into PS2 Slimline, now I have no power. Is there a fuse or some other component that I have to or can replace inside to get it working again?
Esta é uma boa pergunta?
Pontuação 3
2 comentários:
Most likely happened is that it powered on and soon after a capacitor or circuit got fried.
if this is true was there any smoke or the smell of something burnt?
por
Hi oldturkey there was no smoke or smell, the device just simply failed to start. For this reason is why I thought that there might be a protective fuse.
por
Adicionar um comentário
1 resposta
John, attached image will show you all the fuses on your logic board. Use a multimeter to check for continuity of those fuses. Pay particular interest to the resettable fuses. Of course, look for any charred, burned, or missing component as well. Hope this helps, good luck.
Imagem
Esta resposta foi útil?
Pontuação 0
4 comentários:
Cheers for the diagram oldturkey and thanks for the help
por
you are welcome, good luck.
por
Stupid question, how do you reset the fuses??
por
Resettable fuses should reset automatically when the power has been off for a while.
por
Adicionar a sua resposta
John será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 21
Últimos 30 dias: 101
Ao todo: 12,645
