Ir para o conteúdo principal
The Lexus ES is a series of compact, then mid-size, and later executive car sold by Lexus since 1989.
36 Perguntas Visualizar todos
How to fix Rear power window not functioning in Lexus ES330?
The power rear window behind the drivers seat on my Lexus ES 330 stopped working. I hear a whirring noise when I press the window up/down switch on the door but the glass does not move up or down. Any thoughts as to what might be the issue and pointers/instructions on how to fix this would be great. Also if there is a manual work around to open and close the window that could work as a temporary solution, please feel free to suggest.
Thanks!
Esta é uma boa pergunta?
Pontuação 6
4 comentários
^^^^ I felt like I had already written about my problem, SweetPea! It's cold in Nashville, same window is down, and my vain self has a piece of plastic duct-taped to keep the rain and the snow out! Did you take out a Mailbox with your Passenger side side mirror, too? bwahaha - I'm serious!
por
Should I try this? My driver side front window randomly goes down part way and then stops going - sometimes it will start up in a few seconds or a few minutes and it happens randomly. Not sure if it could be the same solution, or something else? Thanks for any advice!
por
Absolutely works, Excellent post. May take up to 5 good door slams.
por
It worked but now the control arm to the window is at the top of the window it has scratched up the entire window cutting into the tint and I'm afraid it is going to shatter the window. I've now taken the panel off to see wtf cuz after slamming the door it seemed to go up then musta fallen again. Now I don't know what to do. That control arm is really strong and I'm not wanting a broken window.
por
Adicionar um comentário
12 respostas
Solução escolhida
Jarro, this is apparently a common issue with your model. There is a TSB out for a fix. You should notify your dealer. For a better information on this as well as a possible fix, check on here. Apparently, following the Lexus forums, this is the preferred fix:"
1. Sit in the seat
2. Open door that window is not working
3. Hold the window button down
4. Slam the door closed
Esta resposta foi útil?
Pontuação 22
36 comentários:
thank you so much ^^ i have been trying to figure that out for so !@#$ long
por
cory, you are welcome:-)
por
Yes, this absolutely works when you:
1. Start the car
2. Sit in the rear seat.
3. Open the door.
4. Hold down the power winder switch and slam the door.
Yay!!!!
por
Was very helpful !
por
Did not work, tried it 3x. Darn! Front passenger window.
por
Exibir mais 31 comentários
I have had this problem twice on my GS 450H. The solution which worked for me is simple. Remove the manual key from the key fob and insert into driver's door. Turn the key left and hold for 2 seconds. It works!!!
There are many complicated solutions online - try this one first.
Good luck
Laraine
Pontuação 2
3 comentários:
My rear window in my ES330 hasn't opened in a year I tried your solution and it was open in seconds. Great advice thank you!
por
This did not work
por
try the fuse post...
por
I have ES 2006 and had rear passenger side window not working. Tried pushing the switch and slam the door. After three times slamming it worked. This trick works well. Wow !!!!!
Arvind
Pontuação 2
3 comentários:
It worked for me too on the first Slam. I had already taken the door panel apart before I saw this post. Guess I should have checked ifixit earlier!
por
Worked for me also. Thanks!!!!
por
I am amazed! As a motorcycle mechanic by trade, I never thought this could possibly work! After slamming the door 5 or 6 times, the window started working! Miracles never cease!
por
Just wanted to pitch in and say that oldturkey03's solution is the correct one. However, a few notes to keep in mind is that you do need to slam the door very hard. If you're gentle in fear that it may harm the car, it won't do a thing.
As well, I recall reading elsewhere that the electrical lock does kick in some sort of overheating protection after you use the power window switch a few times, which will render this technique completely useless. After you attempt to use the switch 4-5 times, wait an hour before trying again.
Pontuação 2
1 comentário:
That is NO JOKE...I had the driver side door open for extra "umph" and SUH-LAMMED the back door with button down and car running and VOILA'!!
Many, many thanks! Love people helping people...not enough goes around in this world. ;-)
por
I had a sudden problem with rear psgr. window not operating. I heard it "click" when pressing the button...so knew it wasn't electrical problem. I took a towel against top and sides of window...and tapped my fist to possibly loosen window. It had been thru several car washes...and evidently it had created a "seal"... so...sure enough...it loosened window...and viola---worked again!!!
Pontuação 1
I can’t believe that actually worked!!
  1. Start the car
  2. sit in the seat with he bad window
  3. open door
  4. hold down the window button on door
  5. slam door very hard while holding down button .
  6. thid time was the charm for me. Just remember you have to slam the door very hard.
thank you all for your help!!
Pontuação 1
4 comentários:
I have been reading about slamming your door very hard. Well my own trick if you dont wana slam your is simply start d car, hold down d button on d bad door, and pound d door from the inside with ur fist somhwere in d middle behind the door opening flip. Dis should work just once
por
This worked. You guys are great
por
This is Amazing. It worked for me. Thanks
por
I was skeptical but it worked. Had to slam the door hard four times but it worked. I would also suggest prior to slamming, press with your hands around the inside and outside of the window where it seats with the door to loosen if it's stuck. Thanks for your help!
por
My mom had this problem on her Lexus also. After reading all the replies here and the fact that I could hear the relay or switch in rear window trying to work, I did this:
Got one of my thin plastic auto body trim tools and ran it around underneath the rubber window seal from the outside. Instantly fixed it with no door slamming. I figure as someone else here said that soap residue from the car wash could be the culprit. I suspect it was. Literally 15 seconds to fix. A person could use a credit card or other slim piece of stiff plastic to do this. No special tools required.
Pontuação 1
Hello to all , stop slamming your doors , if that is what it takes to get your window to work then, it is a good chance
that is what caused your window not to work in the first place .
here is my story , same problem window would not move yet one could here the relay clicking on and off as i released the button for the window
First try a credit card all around the window to ensure the seals are not sticking to the window easy enough right ! do inside and outside now use silicone spray in the rubber both sides of the glass , no worry you can windex afterwards
if this fails try next step (NO DO NOT SLAM THE DOOR LOL)
Remove the door panel check Google how to do it , do not be intimidated it is easy stuff , watch out for the wiring used for light and switches , no worries everything just snaps back into place
locate the motor hold down bolts and with a ratchet loosen slightly each bolt , you do not want to remove them
if the window jambed there is a load on the motor by loosening the bollts you will here the motor shift back into a less stressed position tighten bolts plug wire test up and down .
if at this point the window does not work verify power to the motor if power is a yes you will probably need a new window motor
i hope this helps just remember cars are like people no one likes to get slapped when something is wrong :)
Pontuação 1
2 comentários:
And for those who love taking care of your cars , a good habit is to occasionally role the window completely down and pass a rag in between the rubber seals , then another rag sprayed with silicone , takes 5 min a window do your trunk seals to , keeps them clean and soft , great before winter also
por
Spot on solid advice.
por
On the RX350 2013 rear passenger on driver side window does not open. Slammed the door while holding switch down. Window opened. Great!! now tried to close it and its stuck in open position.
So slammed door again and it went up half way. Had to do a bunch of slamming to close it all the way. Now its stuck in closed position
Slamming door works for a while then problem recurs. Anyone have this experience of the problem recurring ?
Pontuação 1
1 comentário:
I have answered this type of issue before the problem is people ,to rough with your cars ,close your doors ,stop slamming them , u need to open th e the door panel an just loosen the bolts to the window motor when the window is closed , you will here the tension relax retigthen the bolts ,stop slamming your door
por
on the left side in front the driver there is a fuse box behind where the coin saver is... look for the yellow 20 amp mini fuse. there are 2 side by side ......I changed the left one that is for the rear window motor passenger side the right one is the drivers side rear door window..... so I changed the 20 amp fuse and walllaaaaa the window works like it should!!!!!!!!!!!note the fuse will not show its cut but the prongs show brown deposits not silver clean.........
Pontuação 0
1 comentário:
2005 ES 330 95,000 miles
por
You got to slam the door hard while holding the down button for that window
Pontuação 0
Yes. It works. Slam the door very hard. Try to knock it off it’s hinges. That one is crazy true. If you don’t slam like you want to break the door, nothing wont’t happen at all. It works!!!
Pontuação 0
1 comentário:
Just tried this on my 2004 Lexus ES 330 and it worked! My rear passenger side window was open and would not close for the last week. This has happened a few times but would always work after restarting the car and pressing the button. Thanks!
por
Adicionar a sua resposta
Jarro será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 51
Últimos 30 dias: 244
Duração total: 49,073
