Wiki contribuído por estudante
Uma equipe incrível de estudantes do nosso programa de educação fez esta wiki.
Blender Will Not Turn On
Blender does not respond when you attempt to use it.
Outlet Issues
Check to make sure the blender is plugged in properly and that it is a closed circuit, meaning that if the outlet is controlled by a switch, make sure the switch is turned on. Additionally make sure that if your outlet has a built-in GFCI circuit breaker that it is not tripped by pressing the reset button.
Blender Still Will Not Turn On
This may be due to a problem with the power cord including overuse or other damages, and can be replaced as shown here.
Blend is Not the Right Consistency
You are having trouble getting your blend to be the right consistency, whether that means it’s too liquid-like or too chunky.
Ingredients Are Under Processed
If there are chunks in your blend, then don’t pack too much into the blender at once. For best results, keep ingredients under the 64 oz. line and cut them up beforehand to make them fit better if need be and use short pulses so that the ingredients have an increased chance of circulating throughout the blender.
Ingredients Are Over Processed
If blend is too runny, then make sure that you did not put too little in the blender and avoid blending it all in one pulse. For best results, make sure to use many short pulses when blending until the desired consistency is reached.
Blender is Still not Blending as Promised
Even when you don't put much in the blender, the consistency is still chunky.
If this is happening, it means you have a dull blade and will have to replace it, as shown here.
DO NOT ATTEMPT TO SHARPEN THE BLADE ON YOUR OWN
Blades Won't Turn
The blades are not moving or are not moving as they should
Damaged Motherboard
If there is no sound coming from the blender when the blades should be turning it could be the motherboard's connection is bad and the motherboard needs to be replaced.
Blender Overheats
Blender gets very warm or shuts down while running
If this is the case the fan likely needs to be replaced, as shown here.
Leaking Blender
Liquid comes out of the blender while in use.
Broken Jar
If the leaking is a result of a crack in the glass jar, then you will have to purchase and replace it with a new jar.
Liquid Gets in Electronic Circuitry
Blender gets submerged in water
Discard immediately as this could potentially deliver a very powerful electric shock when plugged in again.
3 comentários
Blender Frozen smoothie mode reads Err
David Hill - Responder
I put some milk in then my frozen fruit and it begins fine and starts crushing then it stops and light flasher. I ha e to remove all contents unplug blender then put everything back and and restart It keeps happening. What ami doing wrong
Laura - Responder
Why the frick do you put star bits screws amongst phillips head. What on earth are you thinking.
On top of that they seem to be specialized star bits that require a hollow centered star bit screwdriver.
This alone will make me never buy this brand again. Flat out stupid
Joe skuce - Responder
