Ir para o conteúdo principal
Nutri Ninja Ninja Blender Duo BL641 Blade Replacement
O que você precisa
  1. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement, Blade: passo 1, imagem 1 %32 Nutri Ninja Ninja Blender Duo BL641 Blade Replacement, Blade: passo 1, imagem 2 %32
    • Make sure blender is turned off.
    • Lift open the lid of blender by pressing the "Release" button and move to the side
  2. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: passo 2, imagem 1 %32 Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: passo 2, imagem 2 %32
    • Carefully Grab the top of the blade and pull upward with medium force.
    • The blade should slide out easily.
    • Do not touch the blades! Even when dull they can still cut you.
  3. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: passo 3, imagem 1 %32 Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: passo 3, imagem 2 %32
    • Carefully pick up the new blade and match the bottom star shaped opening to the star shaped protrusion from the blender.
  4. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: passo 4, imagem 1 %32
    • Slowly connect the two star shapes together and push down until it reaches the bottom.
Conclusão
Now your blender can resume blending to perfection.
Charlotte
Membro desde: 09/26/17
101 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S7-G1, Banghart Fall 2017 Membro de Cal Poly, Team S7-G1, Banghart Fall 2017
CPSU-BANGHART-F17S7G1
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 28
Duração total: 3,204
